Use Opacity map as Bump map in keyshot 7.2 Pro
Started by Davitazizyan, December 18, 2018, 06:46:18 AM
Davitazizyan
I have connected Color Composite node to the Material Opacity node. Now how can i use the opacity map (Color Composite map) as Bump map. I can't connect  Color Composite node to Bump Add node.
Davit.
bdesign
Hi Davit-
As you have discovered, a Color Composite node cannot be plugged into the bump channel. As an alternative, you could plug the Noise and Scratches textures into a Bump Add node, and use the Color Gradient as the Weight for the Scratches texture.
Cheers,
Eric
