Author Topic: KS 8 Frames Per Second issue  (Read 1276 times)
Offline Kennady
« on: December 18, 2018, 12:13:36 pm »
Hi fellow users,
Running KS 8.1 Pro latest update on PC Win 10 & Mac Mojave.
Rendering an animation to 32bit frame output. Project is 25 fps.
Issue: When I set the fps in an animation to 25 fps from the default 30 fps, the output still renders at 30 fps.
I notice that when I go to click on the fps box that clearly says 25 fps, the dropdown highlights on 30 fps. Even if I save this new setting, close and reload the file, it'll revert to 30 fps on output. The fps box still show 25.
My only workaround is that when I load an existing file I have to manually change it to something other than 25 and then select 25 before rendering. Not ideal in a production workflow.
Any help?
Offline Kennady
Re: KS 8 Frames Per Second issue
« Reply #1 on: December 18, 2018, 01:13:42 pm »
I think I've figured it out...   ::)
I believe KS is rendering the right FPS output but the metadata when importing to After Effects is wrong. A simple reinterpret footage change inside AE to 25 fps fixes this issue.
« Reply #2 on: December 18, 2018, 01:18:25 pm »
Thanks for posting your find. Might help someone in the future.
And yeah, After Effects. Sometimes it does what it wants to anyway no matter what :)
