CVT Transmission
Started by RocketNut, August 26, 2011, 07:47:10 AM
RocketNut
Apart of a larger motor I'm working on. This CVT controls the speed of a pump to have constant flow and pressure.
aebstract
This is cool, are you doing the entire engine and transmission from the ground up? I think your shout would look a lot better (and probably get some more responses) if it was at a different angle so you can tell what is going on better. Looking forward to seeing the final :)
RocketNut
Yes I amy building a very very large engine from the ground up. There is 4 of these CVT in the engine.
