Turntable render around a pivot point
Started by rfollett, September 06, 2011, 04:57:43 AM
rfollett
I'm sure you can do this but failing.. I need to create a turntable 360 deg render around a part of the model.. is this possible?
Richard
This is currently not possible. Only around the object center or the environment center.
PhilippeV8
So drawing an (invisible) line box around the object and put your detail in the center of that box should help with this ?
rfollett
This might be ok.. So if I have an file with multiple objects in tree , are you saying I can revolve around that object..
Example might be a car, can I revolve around a wheel? if so what is the workflow?
Thank you for your help.
rfollett
So can someone please help?
Can I revolve around individual object within Keyshot? If so how??
Thanks you
toffmon
i have to dig this up, i'm sorry, but i'm having the exact same problem here :P
is this possible yet? can i tell keyshot to rotate a certain point that aint the model or enviroment center point?
