NVIDIA Quadro 5000 - How can I utilise its full power?
Started by taffyb, September 13, 2011, 01:31:55 AM
taffyb
Hi all,
I've just installed a new graphics card into my machine with the spec of:
Asus Rampage III Extreme,
Processor Intel core i7 CPU, 980@3.33ghz - Overclocked to 4.17ghz,
24gb RAM
64bit Windows 7.
I've just installed the graphics card & i'm noticing that on the monitoring software i'm running to check the cards usage that only approx 25% of the cards power is being utilised in both rendering & usage.
How can optimise the software to make the most use of the card?
Brent
PhilippeV8
KeyShot is CPU based render ... not GPU.  Isn't it ?!?
taffyb
Cheers both - never mind.
I seem to have another problem now though in that when i hit render an constant alarm beep goes off & only stops when I stop the rendering.
Any ideas of what could cause this?
Brent
PhilippeV8
My guess is that you have set a max CPU temperature in your bios and as soon as you start rendering and it gets to 100% CPU load it starts to heat up ?
jhiker
Quote from: Thomas Teger on September 13, 2011, 10:54:37 AM
Yes. CPU only.
Don't you need a GPU supporting OpenGL and 'frame buffers' to take advantage of the 'Realtime effects' i.e. bloom and vignetting?
Ralf-S
Quote from: jhiker on September 16, 2011, 12:32:51 AM
Yes. CPU only.
Nvidia -> Cuda    :)
Yes - but any graphics card does that.
Ralf-S - what do you mean by Nvidia -> Cuda? Certainly NOT for KeyShot.
taffyb
Hi all,
Thanks for the responses - turns out that the power supply for the computer had a fault & wasn't up to the job - new power supply going in tonight.
I have another problem - but I'll start a new thread for it as it seems not to be related.
Brent
