Command Line question
Started by carterhickmandesigns, February 10, 2019, 10:18:08 PM
I am trying to evoke a script thru python on the command line and getting 'lux' not defined.  If I am running the script via command line do I need to import the lux and lux.math modules?  If so how?  I have looked thru the 'bin' folder and the 'modules' folders but no luck so far.
The script is very simple and trying to run it on a scene that is already open.  I feel like I need to import a module or something.  Can you tell I am new to command line stuff  ;D
# AUTHOR
# VERSION 0.0.0
# Write description of the script here, and put your code after these lines.
print ("testing")
lux.setCamera('Camera 1')
Thanks in advance
Carter
HamedHem
From KeyShot Scripting Documentation :
Running KeyShot on the command-line: keyshot.exe (optional file to open) -script <python script file> (optional script arguments..)
Here is an example on how to run script from CLI
/Applications/KeyShot8.app/Contents/MacOS/keyshot -script /Desktop/test.py
There is no need to import KeyShot main modules in script, to make sure it's working fine with your scene file , add your scene file path to the command :
/Applications/KeyShot8.app/Contents/MacOS/keyshot  /Desktop/sample_scene.bip -script /Desktop/test.py
regards.
