Processors
Started by JuhaL, February 25, 2019, 04:20:49 AM
JuhaL
Is it possible to set a number of a core during a rendering? I know I can set before starting. I have a lot of situation where adjusting of cores reduces rendering time. Now I set only 4 cores for rendering but it is fine to set from 4 to 8 before coffee or lunch time.
Hi Juha,
Do you want to increase the CPU Usage (number of cores used) after having started a rendering? This is unfortunately not possible.
JuhaL
Quote from: DriesV on February 25, 2019, 06:34:15 AM
Hi Juha,
Thanks for the answer. This is what I'm looking for.
It sounds very uncommon, but you can try using the Region render (pro feature) and render different parts of the image with different CPU usage and stitch them in post.
If you do not change the settings, all region should look like rendered together.
Good luck
