White dots on render
Started by Andrew_G, February 25, 2019, 05:07:17 AM
Andrew_G
I try to render particular scene with a lot of milk (semi transparent) plastics. But unfortunately I`m getting a lot of white dots. I have no idea, how I can eradicate them. I tried to turn off GI - it helped a little but still didnt look good. And in general I want to use GI as some parts of the render became to dark (especially this milk plastic behing glass). I tried a lot of different render settings and all failed. What's worst the longer it render the more white dots are appearing. Do you have any ideas, how can I fix it?
Below is a sample image of those white dots.
There are several forum entries/ threats or get rid of the ,,fireflies" (most common search word).
Most of the tips reduces the roughness, increases the samples and/or the material parameter samples (roughness or ...).
Sorry for the short form, wrote this on a mobile
Esben Oxholm
Hi Andrew.
Have you tried increasing the material roughness samples (if possible)?
While I do agree it's best to get rid of this in KeyShot, it can be close to impossible sometimes and if everything else fail, doing a bit of photoshop clean-up work might help you.
Here's one method:
https://youtu.be/XeZSUR-_Svw
Andrew_G
Hi Guys,
Thanks for answers:)
MWo Yes, I read a lot of these topics and nothing helped. I found out that I can play along with roughness to avoid this fireflies. But I did'nt want to do it. Roughness is responsible for how my material looks like, and I dont want to interfere with this.
Esben Yes! After I started this topic I found your tutorial. And along with some materials tweaking it helped me a lot. Thank you and good work!:)
Esben Oxholm
Quote from: Andrew_G on February 26, 2019, 10:49:54 PM
Cool, that's great to hear.
