Number Fade - Question
Started by kyozon, February 28, 2019, 09:20:39 AM
kyozon
Hello there!
I wanted to know if there is a way that I can add a Number Fade node to the Shift in the Color Gradient Node. This should allow me to change between my Colors for a LED in an animation.
Eric Summers
Drag the output from the Number Fade onto the Color Gradient node and you'll have the option to connect it to the Shift.
What about using a Color Fade node for the color change instead of using a Number Fade to drive the Shift?
kyozon
Thank You!
I just tested the Color Fade Node and it turned out to be even better results!
Eric Summers
