If that is a laptop, that might be the heat management kicking in and slowing the FPS way down. Can you take a look at the Ghz speed that the processor is running at and see if that is dropping as well when you notice the FPS drop? That would indicate some sort of thermal throttling going on. Other than that, keyshot won't slow things down at all unless the OS forces it.
