Milling Tool
Started by Ananth Narayan, May 31, 2019, 07:51:00 PM
Ananth Narayan
Hello, can you give feedback on renders. Also suggest a way to choose perfect HDRI for given model.
HaroldL
 ??? For your chips rev image -- your cutter isn't going to make square corners. I would radius the corner of the milled cut on the block to match the radius of the cutter.
Ananth Narayan
Yes, you are correct, how about this post: https://www.keyshot.com/forum/index.php?topic=24525.0. Really worked a bit.
