ring
Started by raapane007, September 25, 2011, 09:38:21 AM
raapane007
white gold ring with rubys and diamonds.
Zander85
fario
very nice, but a little bit too clean.
Antoine
Ed
Nice lighting.  Crisp, sharp render.  I would just crop the image to concentrate on the rings.
Ed
raapane007
Thanks guys,
I tried to render it in white background but i can't understand why my diamonds going black inside.
any ideas?
What did you do - hide the environment?
raapane007
no i just change color of background box. i think i didn't hide environment.
Still seems strange - how many ray bounces do you have set? Also, is detailed indirect illumination set? Both are located in the the realtime tab.
raapane007
i had ray bounce 14 and indirect illumination was off. but how much gamma and brightness i have to put?
Ok - indirect illumination needs to be on. Gamma - I suggest you increase it. You decide. Hey, it's interactive ;-). You will see when enough is enough ....
Zander85
The keyshot webinar on rendering jewelry suggests setting the gamma to anywhere between 1.8-2.2  ;)
Arnaud
Quote from: Zander85The keyshot webinar on rendering jewelry suggests setting the gamma to anywhere between 1.8-2.2
Depends a lot from the HDR !
Zander85
Yes, but that was what they suggested for using with the Jewelry Soft Box Light Studio HDRI. It goes without saying that you need to tweek to make it work for your scene. I just wanted to help him get in the right ball park first.
