Cutaway Fix
Started by FIT, June 20, 2019, 03:11:37 AM
FIT
Hi Guys,
We had an issue (that later we found it is a known issue) with the material eliminated by the cutaway still affecting the surface near and "in" it.
After loosing our hair we found a quick fix - just add a color fade animation to the material you are cutting and link it to the transparency node. No need to go from white to black and effect the material, a very minor change to grey will do the trick.
