Author Topic: While rendering video, why am I getting white lines on the edges of the labels ?  (Read 4726 times)
Offline brahmzxc
  • Jr. Member
The label is a PNG image with no white lines on the edges.
« Last Edit: August 22, 2019, 03:48:11 pm by Bruno F »
Offline Bruno F
  • KeyShot Support
  • Full Member
Hello brahmzxc,
Thank you for submitting your post. The white lines around the label could be due to z-fighting between the labeled object and the white object right underneath. Here are some things to try:
1. Add a very small translation to the model's position (not the label itself).
2. Change your render mode: Product or Interior.
3. Increase "Samples" and "Anti-aliasing" in your output render settings.
4. Try applying the image as a color/diffuse texture instead of as a label.
