Multi colored dots material
Started by Franfou, August 05, 2019, 04:55:00 AM
Franfou
Hello Im new to this forum, I'm looking to create kind of polka dots, but not with a downloaded png image.., I would like to know how to create that pattern using only material graph, where i can set many colors and distance between dots and size , etc.. kind of possibility we see in the material graph of camouflage pattern,  but with dots instead... Thanks guys !
Every colored dot has the same distance to the dot with the same color. So you can create the one pattern using a procedural mesh (dots with triangle space). Then you can copy this pattern 3 times and use the U and V parameter to shift the dots.
So it is just a question about the correct values.
Franfou
Thank you ! I will try it today ! :-)
