This is an issue that i encounter often. In the attached file you see the issue clearly. I rotate a cam with attached rods, pivoting around two connectors. In the first rotation works as expected. When I mirror those three animations (I tried to mirror those one by one and also all at once), the mirrored animation falls apart. Any ideas why that is and what can be done to avoid it?
