Import Multiple Models
Started by adamwade, October 11, 2019, 03:31:57 PM
adamwade
When using the Import command can we just shift and click on multiple models to import simultaneously.  It would be nice to bring in different concepts at one time instead of importing 10 times in a row.
I used a part of the script from Dries, that he published at the blog section.
https://blog.keyshot.com/keyshot-scripting-tutorial-automate-your-rendering
Here you can find the brakedown of the script. If you only use the import part as a single script, you can import all files of a specific format from a folder. All files will be imported in the same way.
Our customer work successfully with this.
And maybe some adds to the script could be developed for your purposes.
Hope that helps.
adamwade
