Author Topic: Gradually turns from opaque to transparent  (Read 2757 times)
Offline Zvi
« on: November 03, 2019, 02:27:19 pm »
Is there glass material that gradually turns from opaque to transparent glass?
Offline NM-92
Re: Gradually turns from opaque to transparent
« Reply #1 on: November 03, 2019, 03:15:08 pm »
You'll have to use a gradient texture to control the opacity. Can't remember exactly what parameter you have to texture but it can be done.
Offline INNEO_MWo
  • Total likes: 58
« Reply #2 on: November 03, 2019, 10:58:05 pm »
Hello Zvi, ciao Nico.
I would use a glass material as base and apply a diffuse or slightly rough plastic as label on top.
The opacity from the label can be controlled by a fade texture like Nico mentioned right.
Hope that helps
Online TGS808
« Reply #3 on: November 04, 2019, 11:35:34 am »
Nice execution of this look (and how to) here:
https://www.keyshot.com/forum/index.php?topic=21577.msg92028#msg92028
Offline Zvi
« Reply #4 on: November 04, 2019, 01:50:15 pm »
Offline Zvi
« Reply #5 on: November 07, 2019, 04:49:14 pm »
I tried, but  there was no gradient, as you can see in the attached image and ksp file.
« Last Edit: November 07, 2019, 04:56:37 pm by Zvi »
Online TGS808
« Reply #6 on: November 07, 2019, 08:38:58 pm »
Try this. It has a multi-material on it with two options. One with Eric's method (map the Diffuse and Specular Transmission channels with Color Gradient nodes) and the other with Marco's idea to use a label controlled by a gradient
Offline Zvi
« Reply #7 on: November 07, 2019, 10:43:34 pm »
Magnificent!
 How do I turn the gradient so that the white is up and the transparent down? I tried to change the angle and it didn't work.
Online TGS808
« Reply #8 on: November 08, 2019, 06:56:25 am »
Reverse the positions of the black and white colors in the gradients and then adjust each one so that the transition occurs where you want it to.
Offline Zvi
« Reply #9 on: November 10, 2019, 03:55:13 pm »
