Buddha_Small Statue
Started by fa2020, November 11, 2019, 11:31:57 AM
fa2020
First KS9 shot. The cloth is from Sample Scene comes with KS9. The statue has been textured in Substance Painter and imported using special Plugin, KS9+. Total render time using Denoiser was about 15 minutes.
I hope you like it.
GS3D
Nice work.
How did you setup Substance to export the channels needed on Keyshot 9. I can't match the Substance result even if adding the additional channels. Thank you.
fa2020
There is a pre-made export setting for SP that works with KS9+. But for achieving the same result as SP, you need to adjust gmma of the roughness image in KS9.
GS3D
Would you mind sharing the material network in Keyshot and the channels used in SP to export the correct maps? When I use the Keyshot 9+ export option it only exports the PBRS channels which not includes the Specular, Anisotropic and Anisotropic angle which seems to be used on the KS 9+ export
