Dark gray peeled paint or wrinkler paint
Started by Roberto Giussani, November 15, 2019, 12:51:12 PM
Roberto Giussani
Someone can help me to find this material ? Dark gray peeled paint or wrinkler paint.
Thank you.
Search the cloud library for hammertone. I use this all the time, might be able to get that to work.
Roberto Giussani
Thank you ... You solved my enquiry ... ciao
Roberto Giussani
#3
Thanks again for the HAMMERTONE material but I have a little problem. If I use it as a texture (legacy tecture mapping) some thin white junction lines remain between one frame and another.
KeyShot
It looks like the underlying texture is not repeatable. You can improve this by switching to triplanear mapping and perhaps add some blending along the edges.
Roberto Giussani
Thanks for your solutions ... but I've tried and I can't fix the problem.
i don't understant how I can use material with "triplanear mapping" ... thks
Why does the procedural noise (texture) in the bump channel doesn't work for this material?
jhiker
Paint - textured might get you there..
RRIS
besides the aforementioned options, mold-tech presets could work as well, just change the material type from plastic to paint..
Roberto Giussani
Hi Mr.jhiker ,
With your solution and directions, I solved the problem.
Congratulations and thank you!
