Author Topic: Dark gray peeled paint or wrinkler paint  (Read 2415 times)
Offline Roberto Giussani
« on: November 15, 2019, 12:51:12 pm »
Someone can help me to find this material ? Dark gray peeled paint or wrinkler paint.
Thank you.
Re: Dark gray peeled paint or wrinkler paint
« Reply #1 on: November 15, 2019, 01:17:15 pm »
Search the cloud library for hammertone. I use this all the time, might be able to get that to work.
« Reply #2 on: November 15, 2019, 09:47:05 pm »
Thank you ... You solved my enquiry ... ciao
« Reply #3 on: November 17, 2019, 08:10:51 am »
Thanks again for the HAMMERTONE material but I have a little problem. If I use it as a texture (legacy tecture mapping) some thin white junction lines remain between one frame and another.
« Last Edit: November 17, 2019, 08:21:19 am by Roberto Giussani »
Offline KeyShot
« Reply #4 on: November 17, 2019, 05:14:46 pm »
It looks like the underlying texture is not repeatable. You can improve this by switching to triplanear mapping and perhaps add some blending along the edges.
« Reply #5 on: November 18, 2019, 11:47:07 am »
Thanks for your solutions ... but I've tried and I can't fix the problem.
i don't understant how I can use material with "triplanear mapping" ... thks
Offline INNEO_MWo
  • Total likes: 39
« Reply #6 on: November 18, 2019, 01:37:32 pm »
Why does the procedural noise (texture) in the bump channel doesn’t work for this material?
Offline jhiker
« Reply #7 on: November 19, 2019, 12:59:26 am »
Paint - textured might get you there..
Offline RRIS
  • Total likes: 11
« Reply #8 on: November 19, 2019, 04:08:07 am »
besides the aforementioned options, mold-tech presets could work as well, just change the material type from plastic to paint..
« Reply #9 on: November 19, 2019, 07:32:33 am »
Hi Mr.jhiker ,
With your solution and directions, I solved the problem.
Congratulations and thank you!
