Author Topic: Trouble with bubbles in liquid (Can not see any bubbles)  (Read 2567 times)
Offline Urban
  • Newbie
« on: December 28, 2019, 01:12:04 pm »
Hi I am new to bubbles and wanted to try it.
I have a solid glass shape made out of solids in Rhino.
I Choose solid glass
And liquid Chardonnay.
My aim is to create Champagne look at Another file later, with Champagne
bubbles for New Year Celeb. I know I then need to use color gradient to manage this look..
But unfortunately I cannot get bubbels to work at all.
After material graph bubbles node in to geometry..
I have tried several sizes. And no bubbles.
Just to be sure I also tested with material with bubbles like Coca cola and soda.
And same result...no bubbles at all after executing the bubbles node in material graph.
What am I doing wrong?
Please help
Thank you in advance!
/URBAN
Attached file and in material graph bubbles attached, see if you get the same result or if you can help me create any bubbles in this file. Thank you!
« Last Edit: December 28, 2019, 01:23:14 pm by Urban »
Offline TGS808
Re: Trouble with bubbles in liquid (Can not see any bubbles)
« Reply #1 on: December 28, 2019, 02:54:56 pm »
You just have to change some of the settings in your bubbles node. Compare the attached file to your original. Also, I see your liquid is made up of two separate pieces of geometry. It might be better to make it one single piece.
Offline Urban
  • Newbie
« Reply #2 on: December 28, 2019, 05:15:29 pm »
TGS808 Thank you a lot for your Quick answer!
The file worked fine and now I also
managed to change the values
to better result in the original file. Simply great!
Agree. I will group or join the liquid before
Saving in Rhino /exporting to Keyshot.
All the best,
/URBAN
« Last Edit: December 28, 2019, 05:18:58 pm by Urban »
Offline TGS808
« Reply #3 on: December 28, 2019, 05:17:34 pm »
Good to  hear. Glad it  helped.  :D
