If you're using an image texture, then you need what's called a seamless texture. Even if it's seamless though, at that scale, you're likely to see a pattern. The answer is to use a much larger texture that looks more uniform and has no seams. Better yet, use a procedural texture like the built-in noise or fractal noise KeyShot has.
