bake components before adding a new group !!
Started by designgestalt, March 14, 2020, 04:27:52 AM
designgestalt
every year I hope this is fixed ....
I make a lot of renderings of products for visuals for one of my clients, that share a lot of components.
so my files are a cluster of parts in the end.
some of the products in the end will have some sort of turntable animation (it is a bit more complex than just a turntable, the products should rotate to bottom and top while rotating around themselves to show all sides!) , so I create multiple animations for one modelset and than copy them to the other products/ modelsets.
however, I can only copy one animation at a time (since I cannot choose multiple animations or maybe group them!) . Very annoying and time consuming!
the only workaround is to replace the product in the modelset.
yet either way I have to add all my components into a new group, in order to apply my animations to all of my parts!
when I do so I loose a lot of my labels and textures, which I have to manually re-position or in the case of textures re-scale.
sometimes the textures also change their projections style (i.e. form box to planar!). So basically I have to check every part with a label and every texture again!!
very annoying!!!
there should be a possibilty to "bake" your parts/ components once you have everything adjusted!
and there should be a possibilty to copy multiple animations at a time !
cheers
designgestalt
