Configurator Naming Swap
Started by ifeldown, April 18, 2020, 11:36:36 AM
ifeldown
When using the naming tool in the configurator, specifically setting the files to be named using the active model sets, the resulting names tend to get flipped around from the previewed name.  Is there a way to set the order of which model set comes first in the naming?  It doesn't seem to have any correlation to parent/component status.
DerekCicero
Do you mean the order they show up in Presentation Mode?
ifeldown
No, when setting what the output file name is you can designate that it be the model set names.  The file I am having this issue with has one parent and one component per render, but the output doesn't match the name preview even if I swap what the parent and component are.  I am creating a large library of renders that are tied to a spreadsheet so having the names come out consistently is preferable but I was able to work around this by using a bulk renaming program that can swap the order of a file name, etc...
I will post a picture of what I mean when I next remotely access Keyshot 9.
