Render Issue
Started by Paul Lang, April 29, 2020, 09:31:15 AM
Paul Lang
Have two issues,
1. Render producing square artifacts (Interior Mode) only appears in render window and final output, not in live viewport.
2. When renders are complete "finalizing status bar" cycles in an endless loop and have to force quite Quit to get out of it.
mafrieger
#1
There is a new version 9.3 just give it a try and check again...
see: https://forum.keyshot.com/index.php?topic=26115.0
KeyShot
Would you be able to share the scene with support so we can look at it?
Paul Lang
I am using the latest build, Keyshot 9.3.14 which is when the problem started. It is in any scene so I cannot use interior at all as it won't render without these artifacts. I will send one of my scenes to support. Also any idea why when I cancel a render click on x or when a render is finished click the check mark I get and endless looping status bar "finishing" and the only way out is to force quite Keyshot.
cheers,
Paul
Justin A
Hey Paul,
We have file a report with our development team regarding this issue, sending the scene will help with this as it will give our team more fuel for the fire.
Thanks in advance,
Justin
Luxion support
