Author Topic: PTC Creo V7.0  (Read 2125 times)
Offline mikeybabes
PTC Creo V7.0
« on: May 13, 2020, 11:35:32 pm »
Plugin runs on PTC Creo v7 but does not send any data as a live link plugin, PTC Creo v6 worked fine.
I presume the newer features need an updated plugin to correctly support.
As plugins says v3 and greater.
Offline x11d
Re: PTC Creo V7.0
« Reply #1 on: June 05, 2020, 01:39:54 am »
I am running PTC Creo 7.0 and didn't change the config.pro compared to Creo 6.0 in that detail.
It works fine, just experienced some problems with Multi-Body Parts which didn't transfer to Keyshot.
@Mikeybabes: Did you solve your problem?
Offline mikeybabes
Re: PTC Creo V7.0
« Reply #2 on: September 02, 2020, 05:52:07 pm »
Yes if you use the multi-body then you only get the first body transferred over.
I think they need to do an update to fix this, as multi-body is one of the nicer features of Creo v7 is a shame to just having to merge all the time for sake of the plugin.
