Author Topic: Backplate Image conflicts with the Environment  (Read 148 times)
Offline geniusloci
« on: May 19, 2020, 11:17:41 pm »
Hallo, Keyshot community.
I m rendering a Protein model (Ubiquitin) with membrane (liquid).
When i use the Backplate image the edges of the liquid goes dark, and when use the environment as background it goes away.
But I need to use the Backplate Image in this Rendering. How can I avoid the dark areas in the liquid?
I tried the global illumination, bumping up the ray bounces and using self shadows. non of these worked.
I would be very happy if any of you know anything about that.
Thank you very much in advance.
best regards
Offline richardfunnell
Re: Backplate Image conflicts with the Environment
« Reply #1 on: May 20, 2020, 09:31:05 am »
The easiest solution is to render it with the environment visible, but with transparency enabled so you can add the backplate in post. It's a second step but the most straightforward way to get the results you're looking for.
