Hi all,
I'm using the Zbrush to Keyshot Bridge and I have an issue with GPU mode:
In CPU mode, I am able to select the material, click the "Upgrade To New Node" button that appears under Textures, and uncheck the "Apply MatCap" button to have Keyshot use the Vertex Color only.
In GPU mode, when uncheck "Apply MatCap", the MatCap is still being applied.
Let me know if you have any questions about replicating the issue. I'd really like to be able to use the GPU render engine!
System Specs: Windows 10, Keyshot 9.3, Zbrush 2020.1.3
