I assume that's a Daz model. But either way, you need to change the texture to Tiled UV. Make sure the textures are named correctly, see the example, select the folder they are in and choose the 1001 file and it'll remove the seams you keep getting. You may find the texture will be off in colour, just adjust the brightness and contrast to fix.
