Author Topic: work on bigger objects?  (Read 1305 times)
Offline lindasa
« on: July 20, 2020, 07:27:53 am »
Hi there.
เว็บพนันบอลที่ดีที่สุด[
When I have a small object, say a cylinder generated by the keyshot itself, the Glass Gradient feature seems to work just fine.
However, on a 1-meter high cube,  it shows either of the two colours I selected.
I tried everything, changed the scale, the angle, the shift, nothing seems to work.
Any thoughts?
Thank in advance.
Offline theAVator
Re: work on bigger objects?
« Reply #1 on: July 20, 2020, 09:21:16 am »
Does anything change as you rotate around the object?
what is your environment setup (what environment, what size, what settings)?
Do you have any screenshots of your scene that might help people see what you're seeing? That will give people a little more info to nail down what to try first.
