Transparency not consistant
Started by martijnsolar, August 17, 2020, 01:31:58 AM
martijnsolar
For some reason not all solar panels are transparent (which i want them to be). Why does this happen? Changing the products angles makes different panels transparent but never all of them. Have the same problem with multiple setups.
martijnsolar
Problem solved, Keyshot didnt like the fact that i was using multiple transparent objects behind eachother.
if you stack multiple transparent objects, then you have to decrease the ray bounces value.
