Lighting environment
Started by Mikael Prous, August 24, 2020, 01:35:33 PM
Mikael Prous
Was trying to recreate this beautiful shot.
Couldn't figure out an adequate lighting ...
Any tips?
shanespence
Quote from: Mikael Prous on August 24, 2020, 01:35:33 PM
Any tips?
Hi Mikael,
I gave this a go and this is what I was able to come up with. There are two main pins either side and one at the back to create the basic setup. Then I added a highlight with a lot of fall off to each side. Finally, I added 3 black lights (Make sure you change the blend mode to alpha). One to the left, one to the right, and one in the middle with a bit of fall off. Hopefully this helps.
Mikael Prous
Thanks a lot,
I will give it a shot
