grid color, export selected, purge
Started by Öner, September 03, 2020, 09:52:12 PM
Öner
hello,
Grid color; you can add an option to change the color of grids which i use them as guide line.
Export selected; sometimes i need one model on keyshot to use it on another keyshot window, if you can add this option, i can select the model i want in the scene list, then i can export it as a new keyshot file.
Purge, if you use Rhinoceros you may know what i mean.  sometimes i see too much empty layers in the scene list and i can't delete it one by one because i serious its too much.
#1
Hello Öner.
#1: Instead of a colored grid, you can use the frontplate feature from the image styles with custom graphics/ colors and more flexible 'grid'-variations like dynamic symmetry or a spiral. But don't forget to toggle off this option before you render the image.
#2: You can create a new model set from selection. This isolated model set can be saved as a new scene with "Save Active Model Sets..." and then delete the extra model set.
Hope that helps
Öner
thanks but i think it's not the best way to make it easy.
