Author Topic: RTX 2060 Mobile Graphics Compatibility?  (Read 1476 times)
Offline Rollk1
« on: September 24, 2020, 05:53:15 pm »
Does anyone know if the RTX 2060 Mobile is compatible with ray tracing in Keyshot? I don't see the 2060 Mobile on Keyshot's recommended graphics cards (assuming because it has 4gb vs 6gb) but the card should still be able to support ray tracing, no?
Offline Niko Planke
  • Software Tester
  • Global Moderator
  • Full Member
  • Total likes: 13
  • QA-Lead, Luxion
Re: RTX 2060 Mobile Graphics Compatibility?
« Reply #1 on: September 24, 2020, 10:51:02 pm »
Hello Rollk1,
You are correct, while the card is compatible and would give you decent rendering performance, 4GB of video memory will limit you in terms of how large scenes you can render.
So yes is supports Raytracing in KeyShot and should work without problems, but i would still be hesitant to recommend it due to the low amount of video memory.
In case you wonder, scenes that are expected to cause problems include scenes with High Polygon counts and scenes with high resolution textures.
I hope this answers your question.
Offline Rollk1
« Reply #2 on: September 24, 2020, 11:01:11 pm »
Thank you Niko, that’s very helpful. I primarily render relatively simple product studios, so 4gb should be adequate (or at least that’s what my wallet says).
On another note, do you by chance know if it’s possible to navigate keyshot (pan,zoom, etc) via a Windows touchscreen laptop?
