GI in advanced rendering settings issue
Started by yuri_ch, September 27, 2020, 12:16:24 PM
yuri_ch
Who can explain why I'm getting such kind of results when using "advanced rendering settings"?
Compare these two files.
When advanced rendering settings used it looks like global illumination has been turned off compared to maximum samples type of rendering.
Erik Williams
Thank you Yury.
The max samples and max time render settings use a very different rendering algorithm than advanced controls/custom settings.
Some differences in rendering are expected.
​The image seen in the real-time view uses the same algorithm as 'max samples'. If you are looking for an accurate representation of your real-time view I would suggest using either max samples or max time when rendering to avoid any confusion.
I hope this helps. If not, or if there is anything else we can assist you with, please let me know.
Referencing your Ticket ID#:16173
Med Venlig Hilsen / Best Regards,
Erik Williams
Customer Support Specialist
