Loop
Started by Don Cheke, October 01, 2020, 12:48:19 PM
Don Cheke
When creating a turntable animation in KeyShot 9 that you want to loop seamlessly, should a user check or uncheck Render End Frame? Or should something else be done to eliminate the obvious hesitation between loops.
HaroldL
I recall reading in the Help manual that you uncheck "Render End Frame" if you want the anim to loop. Try it then render a Preview anim to see the results.
Don Cheke
Quote from: HaroldL on October 02, 2020, 11:24:38 AM
Thanks Harold. Sorry for the late reply.
