Author Topic: Issue with rendering glossy surface?  (Read 1473 times)
Offline p3ngu1n
« on: January 30, 2021, 06:04:56 pm »
Hey all, quick question regarding 0 roughness material.
I have a scene set up with physical lights. I'm trying to render a high gloss object and am finding that setting the "roughness" slider to "0" is creating a strange situation where the material no longer seems to reflect light.
Attaching some screenshots with various "roughness" settings.
I understand that no object is ever "perfectly" smooth, however, I have to wonder if this is expected behaviour?
Offline Anindo Ghosh
Re: Issue with rendering glossy surface?
« Reply #1 on: January 30, 2021, 09:09:21 pm »
With roughness set to 0, the size of the reflection is exactly the same size as the light source. A point source is a point, so the reflection would be infinitesimal, i.e. smaller than even a single pixel.
With a larger light source, I get a visible reflection even on zero roughness metals, please check if you have similar results.
Offline p3ngu1n
« Reply #2 on: January 30, 2021, 10:26:31 pm »
That makes sense. If I throw an HDR light source it reflects just fine. Thanks!
