Studios keep lost "Environment" settings
Started by CNG, May 04, 2021, 05:19:56 AM
CNG
There is an issue which still happening on KS 10.1.82. Studios cannot remember the Environment setting and reset it to the first one on the Environment list. It usually happens on affected Studios when you creating new Studios or manipulate other Studios, even jumping between Studios or manipulate Model Sets. This is very annoying as you need to keep an eyes on that after you change anything or check every Studios routinely. Set it back and it will reset itself again and again. Does anyone face the same?
Similar problem other users had reported:
https://forum.keyshot.com/index.php?topic=25296.msg106091#msg106091
I cannot login to the bug report forum so I type here. Thank you.
DerekCicero
I have actually spent most of today trying to pin this down. It's definitely happening, and it's a tracked bug, but I can't seem to make it happen with a clear set of steps.
If anyone has clear steps or a scene they can share, please send it to Support.
DerekCicero
OK this should be fixed in the beta next week.
