exterior render
Started by AK, May 27, 2021, 08:34:25 AM
AK
Hi all,
Can you guys provide any feedback please, as I am new to Keyshot.
Zeltronic
Well maybe you can improve rust texture (not sure 100% that is rust or other material ;) ) and try to avoid texture repetition to be so visible, but your renders looks good.. :)
KristofDeHulsters
Like Zeltronic said you want to reduce the amount of repetition in the large flat surfaces. I would also highly recommend adding some variation in your repetitive geometry pieces (such as the balconies). Usually adding some 'technical details' also adds a lot to realism: if you look at reference images of buildings you'll see pipes, wires, AC-units, ... across the face of the building which you currently do not have. Sometimes I even just paint those in in Photoshop to not have to add extra geometry into my renders.
Regardless, your images already look really good :)
