Saving with render option multi-material problem
Started by Fritzie, June 08, 2021, 04:50:36 AM
Fritzie
I set up a good render format file which I am using as a basis for various products. But when I use the multi-material option to render it saves under the file output name of the previous document name/file name, quite strange. A filename that is not used in this file at all. It seems like a glitch but does anybody has an idea how to fix this? Perhaps a setting I missed?
thanks.
PhilipTh
Hello Fritzie,
The Add Multi-Material render option works in a bit of a strange way.
The render job will take the name from the Still Image tab, but the output image files will use the name from the Configurator tab.
