Gravity for Fuzz
Started by Metin Seven, June 10, 2021, 09:39:23 AM
Metin Seven
I'd love to see gravity control added to Fuzz, preferably controllable using a value or greyscale texture (with black causing straight fibers, and white areas getting full gravity pull-down).
mafrieger
Zeltronic
KristofDeHulsters
+1 but you could mimic gravity by setting your direction, right?
Metin Seven
Thanks for your support guys, appreciated.
Kristof, if the Fuzz direction is in world space, and includes bending from the fiber origin (coming straight from the object normal) to the outer end, then it should be possible. Is that the case? I haven't experimented with that yet.
KristofDeHulsters
Quote from: Metin Seven on June 11, 2021, 10:32:37 AM
I believe so, I have seen some people doing rendering of animals and they definitely need directional fuzz. I believe you can input maps even to set the direction.
Metin Seven
Interesting. I'll test that soon, thanks.
