Author Topic: Texture_label Animation  (Read 3850 times)
Offline Radace
« on: June 29, 2021, 05:11:40 am »
I want to ask, it is possible to animate only that "02" texture on object?
I want to make "02 texture" rotate left, but the object rotate right, without use of videotexture
Offline TGS808
Re: Texture_label Animation
« Reply #1 on: June 29, 2021, 05:22:09 am »
No. Using a video texture is the way to go and would achieve this easily. Why are you opposed to doing it that way?
Offline Radace
« Reply #2 on: June 29, 2021, 05:24:31 am »
i got fan model to animate with light on it blades
when blades rotate 1200 rpm, and light video texture on is doint 1 rotate pesr second, its immposible to make, becouse model of fan rotate with animated video texture :(
« Last Edit: June 29, 2021, 05:31:51 am by Radace »
Offline Radace
« Reply #3 on: June 29, 2021, 05:30:28 am »
So, I made, cylinder invisible to camera with video texture on it, everythink works fine, light looks good on blade model inside cylinder, BUT now I got that videotexture cylinder visible to all reflections like glass etc. Is is some way to get rid on that model in reflections?
it have emmisive material on it, not visible to camera, with video texture on it.
« Last Edit: June 29, 2021, 05:32:11 am by Radace »
