Ever since I aplied fuzz I can't open my Keyshot file
Started by margarida98, August 11, 2021, 07:07:03 AM
margarida98
I aplied fuzz to the material and then Keyshot crash. Ever since this happened I can't open keyshot file. It crashes due to an error of memory loss. I've tried to update my Nvidia drive and my pc performance and I still can't open the file. How can I recover my file to change the fuzz so doesn't happen again? Thank you!
You can open the file in recovery mode, found in the help menu. So all the geometry nodes will not be calculated and the scene should be handled within the memory. Then you can apply other materials or change some material settings - the limits in the geometry shader, for example.
Hope that helps
CheerEO
margarida98
#2
It worked! Thank you!
