S24 + Keyshot 10.2 Pro Animation doesn't work at all
Started by Seth Richardson, August 28, 2021, 04:36:20 PM
Seth Richardson
create a simple scene in c4d make a sphere animate it.  Send to Keyshot.  Nothing happens, animation shows up but its not actually animated.
Same with camera animation from C4D, the camera snaps to the world 0 position but appears to have the animation.  Camera animation also crashes with a target that is an object.
Sune
Hi Seth,
Unfortunately the C4D plugin does not support deformable animations, so you are limited to transform animations only.
To use deformable animations in KeyShot, you would have to export your scenes from C4D to Alembic and import those in KeyShot.
As for the camera animations, you are completely right, there is an issue there. We will take a look at it.
