Author Topic: Camera and/or Studios import/export  (Read 1993 times)
Offline DetroitVinylRob
« on: November 03, 2021, 07:00:42 am »
In v10 can cameras and/or studios be imported and exported from KS file to file, if so, how?
Offline INNEO_MWo
  • Total likes: 84
Re: Camera and/or Studios import/export
« Reply #1 on: November 03, 2021, 10:58:13 am »
Yes - you can - just import a bip or ksp and activate the options you need from the scene.
If you need scenes as a template that contains only cameras or studios, then use the configuration of the model assets with a dummy cube (otherwise you'll get an error creating that asset) in the model tab of the library. For further infos look in the manual: https://manual.keyshot.com/manual/models-tab/library-models/
Hope that helps
CheerEO
« Reply #2 on: November 03, 2021, 12:00:50 pm »
Wow, thank you. Looks pretty straight forward. Worked out really nice Marco and allowed us to build valuable (template) scenario files. Cheers!
« Last Edit: December 01, 2021, 05:49:21 am by DetroitVinylRob »
