Remove White Fringes from Transparent Image
Started by brahmzxc, February 17, 2022, 09:48:13 AM
brahmzxc
Hello Everyone,
Can someone help me removing those white fringes from the transparent image.
The format I chose is PNG with Alpha transparency checked.
please help me...Thanks
TGS808
You can do it in Photoshop. From the top menu bar: Layer/Matting/Defringe.
Zeltronic
If you have used ks denoising reduce firefiles filter in most of case do the job ;)
Quote from: TGS808 on February 17, 2022, 10:03:48 AM
This is the way. Its a hotkey for me.
DT
#4
White and Black Backgrounds generally have a matte/fringe as others mentioned it's easily removed in PhotoShop, Go -> Layer->Matting
That said here's a workaround, try changing the Environment Background to Color at 84% grey.  I've been doing this for years.
Quote from: DT on February 28, 2022, 02:34:06 PM
Doesnt this affect your lighting setup though?
DT
Opaque materials like in your render not so much.  Glass and Clear materials, yes.
The 84% gray background is intended for product renders with an alpha transparency.
