First, I agree with Will.
Attached is a quick example render using the settings below.
For roughness add a Granite 3D texture on the bump of the wall scaled to about 0.5cm bump height 0.25.
For depth, add an Occlusion 3D Texture to the Diffuse color be sure to add the wall's Blue color to the "Unoccluded" color, and set the Radius to 5 with a falloff of .5.
Under the image panel select Photographic -> Low Contrast.
The wall trim/molding add a different (paint) material with less roughness.
Edited image to match the lighting better.***
