Author Topic: Help needed with RealCloth  (Read 1171 times)
Offline Lars
« on: April 25, 2022, 09:08:11 am »
Hi there
I want this RealCloth texture to look like the attached photo of the real thing.
I have tried loads of different settings but can't figure it out...
Can anyone help?
Offline Anindo Ghosh
Re: Help needed with RealCloth
« Reply #1 on: April 26, 2022, 03:29:04 am »
It would be helpful if you could point out what aspects you're facing a challenge with. I'd love to take a crack at it.
Also, without either the Keyshot file or the relevant material graph, it isn't clear what you have tried already.
Offline mattjgerard
« Reply #2 on: April 26, 2022, 06:36:51 am »
Lighting lighting and lighting. It looks like your materials are pretty close, but the pictures have a much sharper contrasty lighting scheme to them, evidenced by the sharper refelction on the left side of the vertical one and right side of the one on the right. You are actually probably closer than you think.
Offline Lars
« Reply #3 on: April 26, 2022, 06:43:22 am »
Thank you for taking your time with this. I realise I didn't explain very well.
I'd like the herringbone texture to be just diagonal, marked on the two pics.
« Reply #4 on: April 27, 2022, 09:24:26 pm »
Hi Lars,
For your requirement, herringbone isn't the Realcloth weave to use: That's literally a herringbone pattern, i.e. alternating upward and downward diagonal.
Your pattern is much simpler, a basic 4 x 4 weave. Please see the attached screenshot. I've used Brushed Aluminium as the surface material to make the pattern clearly visible.
BIP file is attached for reference.
Offline Lars
« Reply #5 on: April 28, 2022, 03:30:24 am »
Wow! This is nothing short but amazing!   :) :D :) :D :)
Thank you so much!
You also made me realise I have to learn how to use the material graph more as it's very efficient.
Thanks again
