Shadow trouble
Started by nagelibre, December 06, 2011, 07:18:31 AM
0 Members and 28 Guests are viewing this topic.
nagelibre
I have a problem with the shadow on this particular picture. Even if I push parameters to max, i still have some bad shadows?!?
could you tell me if there is any trick?
Fred
KeyShot
Hello Fred,
Try increasing the shadow quality in the settings tab. Also, you can reduce the size of the ground area in the environment tab.
-- Henrik
This type of shadow has always been an issue whenever the model is dead flat on the ground.  What I do is "lift" the models just a tiny bit.  You won't notice that it's floating if the movement is very small.  Try it...
